froohoo
Hello! I have a KDI-17, and I love the thing because it's fast, it does a good job and it's built like a tank. Recently though I have been having an issue with the infinite timer (I think that's what it's called) due to I believe bad contacts internally. The symptom is chattering of the drain solenoid at some the same points in the cycle, and wiggling the knob will cause it to chatter / stop chattering. I also have a busted interlock switch (electrically fine, but one of the hinge points for the tang are broken. So two questions:
Is the infinite switch serviceable? The semi permanent retaining rings and other assembly details make me think it may not be.
If it is not serviceable, can these timers still be obtained from any sources?
