washermatt
- Joined
- Jan 21, 2012
- Messages
- 13
Hi:
I have a KDS-16 Hobart KitchenAid dishwasher with the Soak Cycle. While the machine works fine, the inner door panel which was originally coated with white porcelain is very pitted. A number of months ago I posted a question asking how best to cover up the pitted area and I received some very helpful answers. Since that time however and most recently, I was able to purchase what I thought was an exact replacement door from a dismantled KDS-16 machine. I received it and, while it is in very good condition, I noticed one difference between that door panel and the one on my machine. Specifically, while the two holes for the rinse agent dispenser on my KDS-16 machine are located in a diagonal configuration on the inner door, the rinse agent dispenser holes on the replacement door panel I received are configured in a vertical fashion, meaning that one is located directly above the other on the door panel. In all other respects, the door panels appear to be identical. I have since learned that the KDS-16 machines came in two configurations, one WITH the soak cycle (which I have), and an earlier version WITHOUT the soak cycle. I was wondering whether the difference in the configuration of rinse agent dispenser holes in the two door panels is because perhaps the door panel I recently purchased came from an "earlier" machine without the soak cycle, or was there another reason? In any event, I was wondering whether I could use the door panel I just purchased (with the "vertical" configuration of the rinse agent holes) to replace the existing damaged door panel with the "diagonal" configuration.
In addition, if I do replace the door panel, I have some other questions. They are as follows:
(a) Can I use the old gasket from the soap dish dispenser when I move it to the replacement door panel? If the gasket does not seal properly, is there a way to get a replacement, or does anybody have any suggestions as to how to properly seal the old gasket? This same question applies to the gaskets for the rinse agent dispenser.
(b) In dismantling the original door, can I simply pull off the pushbutton controls, or is there another way to properly remove them?
(c) I purchased a new door seal which I want to put on the replacement door panel. It does not have any screw holes in it. Do I simply line up the new rubber seal with the screw holes in the replacement door and punch holes with a sharp object, or is there a better way?
(d) Are there any special precautions I need to take in dismantling the old door panel and installing the replacement?
Thank you all for your time in reading this, and any responses anybody can offer.
--Matt--
--Matt--
