KDS-17A Repair question
pattisue
Mar 21, 2021
0
Fort worth, tx
I recently acquired a KDS17A Kitchenaid Supurbera dishwasher. Somehow in transport, the wire that is riveted onto the plastic piece connected to the heat/fan blower, broke off. There's no way to reconnect it to the rivet & soldering doesn't appear to be an option as the rivet is embedded onto plastic. There is thin red coiled wire next to the wire connections & the thin red wire is connected to the rivet. Based on the schematic, this looks to be the safety mechanism in case the heater overheats. How do I fix this?
Broken terminal on the dry blower motor on a KA DW
You can try reconnecting the tiny thin wire to the terminal [ small nut and bolt as Glenn suggested ]
Or just replace the blower motor, these are a dime a dozen on E Bay etc, This is not part of the thermal cut-off for the heater.
John L.
