1zenerdiode
- Joined
- Feb 3, 2013
- Messages
- 3
I recently replaced a cracked drain impeller on my KDS-18. Now, the motor bearings are "singing" very loudly during running (a whine, not a screech).
I purchased a new motor from ebay with the starting relay and bench tested it, and it works fine. It also came with a tub seal and the shim kit / impeller. The original motor appears to be the type without the starting relay.
My question is - how do I remove the motor and pump assembly without having to pull the dishwasher out? Are there clips that I can throw to get it out? Also, does anyone happen to know the shim procedure for the impellers? It didn't come with the gauge and I know that you have to shim at least the bottom drain impeller and perhaps the pump impeller up in the wash arm support but I don't know the clearances. Any help would really be appreciated.
My wife is convinced that I'm nuts, but this is such a nice machine I am reluctant to part with it. I've replaced the fill valve and various other things, and the timer appears to work perfectly. I don't want the motor to lock up with a failed bearing and fry the timer contacts, so I'd like to get it fixed up pretty soon. It has given me over a decade of reliable service since I bought the house.
