Hi, Working on a 42 year old Maytag A710 washing machine. Unit has worked very well up until now. Typically, running 3-5 loads of wash per week.
Washer is now going through entire cycle but leaves the washer full of soapy water.
In troubleshooting, it appears the motor (2-1666-12 as shown on motor) is tripping out the temperature monitor. The timer goes through the rest of the cycle but the motor trips out at each stage and the timer just goes through the motions.
I am able to get the motor to run 1) with no load (drive belts removed from agitator and pump) and 2) drive belt ONLY on the pump pulley (so that I could empty the water). If both belts are connected and attempt to run the agitator, the motor trips out and skips that cycle (the temperature resets/clicks in a few minutes but does not re-engage the motor).
I was able to get the motor to run the agitator for 5 minutes when there was only a "small" load worth of water in the tub. However, I lifted the lid and the motor would not resume on the small load. Again, disconnected agitator belt and was able to pump out the tub using the motor / pump.
Both the agitator and pump pulleys spin easily when rotated by hand.
During the small load trial, there was a fairly significant "grinding" noise coming from the motor. Sounded to me like the motor bearings were whining.
I'd like to get the machine operational but I can not find the 2-1666-12 2 speed motor anywhere.
I'd appreciate any thoughts or suggestions!
Thanks
Thanks
