Hi all,
Just discovered this site, pretty cool. We bought a house around 7 years ago and it has old appliances and haven't had the money to replace so I continue to fix them. Old Tappan 24" double oven, and a Kitchenaid KDS-18, which I had thought about replacing many times but every time we looked at new ones, was not impressed, and slowly over the years have learned that this is a dishwasher worth saving, I know I could put a new one in that would last say 5-7 years, and this thing is 34 years old!! the owner still had the receipt from 2-2-1980, this baby was 460 dollars back then, with copper panel and right side panel since its at the end of the cupboards. Looking over the previous owner paperwork, on 4-16-1980, jus 2 months old, says unit won't shut off-just hums- checked unit-found bad gears in timer-replaced timer unit-OK. Then in 1997, unit doesn't start-repaired burnt black wire at selector switch and checked-OK. Then we bought the house in 2007. Couple years back, would not fill with water. I checked water level valve and eventually found the water fill double solenoid bad, replaced with newer one solenoid version. Recently detergent drawer won't open and every few uses it won't drain. I opened the front and the dispenser shafts had leaked onto the bimetals and rusted them, so I changed those to new metal plastic version and replaced O-rings, now dispenser is OK. I replaced the drain hose with new, checked drain solenoid for obstruction-OK. It still does not do the final drain sometimes, it might be every 4 washes or twice in a row. With 5 kids this thing gets used about 5 times a day, so it happens everyday. Since it works everytime if I press cancel drain, I suspect something with the timer, not the solenoid and pump. I don't understand why it drains in the previous cycles but not the very end?? Timer is around $100 on ebay, new number is 4162399.
Any advice would be appreciated.
IN the meantime, I looked on craigslist and drove one hour and picked up an older KDI-18 for parts, has a dial instead of all buttons, so timer is most likely not the same. That one also did not drain but the drain hose was clogged, tried it once and everything else seemed to be OK. Its a stainless look but no side covers.
