Have run about 6 or 7 normal washes and a pot scrub wash. No leaks. Decided to install, ran a final normal wash no problems. Loosened lower gold band to slip on rubber gasket at bottom of door which had come off partially. Reattached, filled with jet dry. Decided to run short wash--nothing! Canceled wash. Decided to run Normal Wash. Started filling but motor never came on. It filled with water but no motor. Just a humming noise. Canceled wash, timer went through cycles quickly but never discharged water. Washer is now full of water!!! Help. Am I overlooking something, a switch? Solenoid?
