KDS-18 Water Inlet Valve
superba1
Active member
Feb 24, 2018
33
CA
Hello,
Is the water inlet valve for a KDS–21 compatible with a KDS-18? My KDS-18 inlet valve is leaking. I have a inlet valve from a kds-21 but it only has two terminals compared to the four on the 18.
Thanks for your help!
Jeff
Of the 4 wires that go to the inlet valve, there’s a white wire that connects to what appears to be a thermostat and a black wire that goes to the float switch.
John L.
Thank you, John for once again coming to the rescue!
I truly appreciate your help!
It’s all taped up and no more leak.
Jeff
