zenithtv
I have a 2005 Kenmore (D&M design) 18" dishwasher that has a small leak that appears to be coming from where the motor shaft enters the machine. I assume the shaft seal should be replaced (part 36 on diagram).
The service manual states that a special service tool (which I can find no source for) is needed to install the motor so that it is properly centered. It states the tool is also used to install the seal.
Does anyone know if the motor needs to be removed to replace the seal? It appears that the seal is in two pieces, and the upper portion can be removed from the top with motor in place, but the manual is less clear regarding the lower portion. I have ordered the new seal, but haven't disassembled the machine yet.
