moparjoe
Washing machine basically died, and would only fill up, and do NOTHING else after it filled (wouldn't agitate, spin, or even drain).
I poked around in several areas, trying to determine the problem....After much poking, and learning as I went, I figured out the timer was the problem, and got a used timer(s) from Ebay.
After installation of (a few) different timer, the machine will now function, but is not the same as it was before; I have the same results with 3 different (replacement) timers now......Machine won't start filling till part way into the wash cycle time (around 6, instead of 14), and also won't spray rinse water during the SECOND spin (like it use to to do). It also seems to not be agitating as fast as it use to.
I was poking/pulling on some levers initially, on the underside of the washer, thinking something may have been frozen or stuck, and not sure if I changed something under there that could account for the current changes in the machines operation.
Any help on this situation would be GREATLY appreciated, so I can get this machine back to proper working condition, and keep it from getting scrapped; We use it for doing our laundry, and need a working machine.
Thanks in advance, Joe
