mt999999
Member
Hello all,
Long time lurker (for years), but finally made an account.
Pictured here is my 70 series (model 110) Kenmore “water/suds saver” washer, currently in regular use. It was my grandmother’s until she moved. I believe she bought it new, maybe circa ‘97/‘98. From what I understand the suds saver wasn’t common in models this late. Does anyone know when they (any/everyone) quit making this style washer?
I just replaced the water inlet valve. The cold side had a steady leak, possibly from sitting unused in unheated storage since 2014. I just moved, and hooked it up seeing that I needed a working washer. Before it was stored, the only issue (still persisting) was the washer not going into final spin and leaving the clothes sopping wet in the drum. This only happens on the normal cycle, works on heavy-duty. I haven’t tested permanent press/delicate. The timer goes to the end and finishes... it just seems to skip over the spin cycle some how.
Could the issue be the timer gear or something? Hopefully not the timer its self. The water saver and water return functions still work as intended. The trouble is trying to plug this 120 year old concrete laundry tub to hold the water. Interesting that it can save rinse or wash water; 18 or 23 gallons... presumably medium/large load sizes.
The ancient 50’s dryer says “general electric automatic” on the face. I’m assuming circa 1950’s. I tried to look up the model to no avail. It appears to be able to be used on a 110 circuit as well, which I find interesting. I’m not sure what they define as “automatic” since it is just timed dry. Perhaps as opposed to an older style that is just on/off, or a clothes drying cabinet/rack? I’d love to know more about this unit if I can. All I had to do was replace the 15 amp screw in fuse and clean out lint, then the unit was ready to go! I’m also using this dryer on a daily basis. Moving this behemoth in by myself was a trip! I swear it weighs what two modern dryers weigh. One this old at 4,800 watts is probably not very efficient either, but I’m not very sure, having nothing to compare it to.
Also pictured is an old wringer that does not agitate (belt?), but the rollers spin. It is next to an old mangle, untested. And very heavy! And a small apartment sized gas dryer, not hooked up. I’ve only tested the electric on this one. The drum appears to spin as it should. Don’t mind the mess!
