Kenmore 80 Shredded Door Mat Rug
blockeight88
Apr 11, 2021
643
Northwest, IN
Several pieces of my door mat rug were shredded in the washer. Afterwards I vacuumed the remaining debris out but during the spin cycle the washer makes a high pitch humming noise. I do not hear anything abnormal during the wash or drain cycles. Anyone have any advice on what the issue is?
Rubber/Latex backed rugs....
.....just do not machine wash and survive. That is why I only buy non-backed rugs and then put a non-skid "mat" under them. I have found rubber/latex backed rugs start "flaking" after the first GENTLE wash.
Thank you all. I am realized to hear this. I wonder if it would help if I drained the debris out of the drain pump. I am not sure why pieces of the rug would make a humming noise during the spin cycle.
Why Bits Of The Rug Cause A Humming Noise In The Spin Cycle?
Because the pump is turning during the spin cycle, and you have rug bits caught in the pump,  it also runs the opposite direction when washing so the sound may be different, how many loads have you washed since this happened ?
It might take a while to work itself out of the pump.
John L.
I’ve only done one full load since. No picture to share. I was able to vacuum the debris up in the washer drum. Never again. I’m just glad it will correct itself (hopefully).
Just an update: I took the drain pump out, cleaned it out by running it under some water. Put it back together and it still seems to be making the high pitch noise, but it's not as consistent as before. I'm thinking I'll just replace the entire pump. This was very easy to do.
