norgechef
I have a Kenmore direct drive that is very finicky about when it will do a neutral drain. I have found that it will only do a neutral drain on a fast/fast cycle. If slow agitation is used, it will not engage. And fast agitation or not, it has to run the “extra” 14 minute wash cycle, plus a pre-wash (I don’t drain the pre-wash water) for it to engage, it’s almost like it has to “warm up” enough to work, which is fine by me because that’s the cycle I usually use anyways as I only wash XL heavily soiled loads. 18 minutes is the minimum of what is required to get out tough stains imo. Sometimes I give it an extra 4 on top of the 18. Don’t even understand why 14 minutes is considered “extra”. That should be normal, for XL loads anyways. Maytag Atlantis machines had a 35 minute timer programmed agitation for the extra heavy cycle when you added pre-wash.
Side note- Never had a shredding/holes or excessive wear issue I must say, not sure why so many people call these “shredmores”. It’s gentler than an LG top loader I used to own even on fast speed agitation.
Anyways, once in a while washing delicates or bedding when a lower water level is used and I use slow agitation, no matter how long the wash cycle, neutral drain will not engage. This is frustrating because the softener will dispense too early if it missed the neutral drain. I thought the neutral drain packs on these washers either worked, or they didn’t. Clearly that’s not the case with mine. Also have found the machine leaks, only very seldom, on large unbalanced loads. Doesn’t happen often and I can’t find the source, so I’ll leave it be unless it becomes a regular occurrence.
