dustin92
I picked up a Kenmore 24" direct drive a couple days ago (for the friends that have the old crabby belt drive portable), and it's in pretty good condition overall, but I have one issue and a question. The issue is the tub tilts to the right during the wash and rinse cycles, although it seems to spin fine. The problem is, when it fills for the rinse, the tub is already tilted to the right and forward, which causes some of the fill stream to go onto the tub ring and then the floor. Springs maybe? My question is, being that this is a large capacity machine rather than a super capacity, will I be causing any extra wear or damage to the machine by installing a dual action agitator from a super capacity machine? This is a pretty low end machine, no delicate cycle, single speed washer. It currently has the small gray one piece agitator with the weird looking fins about halfway up the barrel and doesn't turn the load over very well. I tried a load with the dual action agitator and it worked great, but I wouldn't want to damage anything by installing it permanently. The agitator I'd like to install came from a lower end new style belt drive (vmw) and it does fit. Are all direct drive machines run by the same components regardless of capacity? I've already ordered a new drive coupler just to be safe, everything else seems to be fine.
