Kenmore dishwasher 66515693K210....new and leaking
skier7
Jan 11, 2014
I purchased this model dishwasher mid Spring 2013. By November 2013, I discovered the unit was leaking.....has anyone had any problems. So far a number of parts seem to fail on these units from hours of research. The serviceman is scheduled again with a list of possible issues. Has anyone one had a similar issue??
The model that I have does not have a left and right side tub deflectors- the engineering team changed the design; this was determined directly from Sears engineering department that went through a diagram of where they are located. The spray arms in the dishwasher are not closed all the way- some areas are pulled together, some areas of the spray arm are wider. There has been trouble with the gaskets around the door and soap dispenser, and steam vent grill at the top left corner of the dishwasher (if you are facing the washer, not using an anatomically correct position). Or loose screws maybe? Water inlet valve? The door underneath was wet and dripping favored the left side.....
LG Sourced Machine...
Funny... That was my first thought!
Malcolm
Hope they can resolve the issue and put this to bed. Otherwise, I would get it repaired and sell it on Craigslist then go find another machine.
