Hopefully yours doesn't have a mouse nest in it.
I bought a relatively new Estate (Whirlpool made) dryer from Menards a couple years back, for $19.
It looked good and worked good, but thought I'm going to check the inside JUST IN CASE....
It's a good thing I did as right near the middle, a busy mouse had built a towering nest that, oddly, was all stuck together. With all the moving of the appliance it didn't distort. Apparently the humidity from the basement the dryer had been in glued the mess together. It wasn't quite as bad as the picture but....
Fortunately I opened it up outside, removed the control panel, the top, the front, the back, and pulled out the drum. When disconnecting the belt I could see there was a mess. There was no indication that the mouse had been in any other part of the machine. I propped the dryer up so it slanted to the front, got a hose, and protected the motor with a plastic bag. Then took the hose, some soap, and a scrub brush and cleaned all the crap out. Also bleached it.
Good as new after letting it dry a few days and putting it back together.
