Gary,
There are a couple of points to be considered here. Funguy tends to shoot from the hip, to put it mildly.
This series is one of the oldest and most reliable of the FLs available in the United States.
It has frequently been given quite good ratings by various test organizations.
True, there have been several problems over the years. The most serious of them have all been addressed:
-Static discharge on controller boards led to program interruptions. Fixed.
-Door interlock fails right out of warranty. Fixed.
-Bearing seizure. Fixed and only a problem with a small number of machines, caused by an idiot-young-dynamic-manager-penny-pincher.
This series is well designed and had the teething problems worked out.
It is possible (check the serial number) that this machine's premature failure is, indeed, do to it having that lousy bearing (just because she bought it two years ago does not mean it was built two years ago, it could be a few years older). If that is the case, then there should still be a chance to get it repaired for free. I'd check with Sears headquarters and Electrolux on that.
A more likely cause of the failure is that she either used chlorine bleach frequently and or "normal" American detergents. The suds from these detergents gets into the bearing and destroys it. Chlorine bleach should not be used very often, if at all for the simple reason that the "spider" (the part which takes the load when the drum is turned) is made of aluminum and this metal is eaten by chlorine.
The real question is, does she otherwise like this machine? If so, and the repair is covered by that defective part, then yes!
Otherwise, I think a repair that is now approaching $400 for a machine which you can frequently buy new for less than $500 is too much.
Gosh, funguy, give it a rest, will you? We all know you don't like Europeans, front loaders or people who don't rush to do your bidding. You so very often have interesting, creative things to contribute, but sometimes you really act your age!
Just because a machine is not the most expensive on the market does not mean it is poorly made. Indeed, many of the most expensive American FLs of the last 10 years turned out to be pieces of shit.
