Kenmore gas range
laundromat
Feb 9, 2010
4,209
Hilo, Hawaii
I have a Kenmore gas slide in self cleaning oven range.It has the sealed burners,waist high broiler,automatic self cleaning oven and pilotless ignition. There was a serious leak in the plumbing just above the range and water filled all four of the sealed burner cavities.After the plumbing issue was resolved,I went and dried up all the remaining water and cleaned up the floor in the entire kitchen. I went and turned all four burners on to dry out the remaining water in the jets which worked fine. I went to set the oven and it threw the braker on the outlet (110 volt)not the circut braker.I tried again and it failed again.Without power,neither the oven nor the burners will ignight.I can use a lighter or match to light the 4 burners but not the oven.If I set it to either broil or Self clean,it comes on but if I try to set it to bake,it throws the outlet off.I can reset it but still can't set the bake program.Anybody here have any idea on what needs to be done or if I need to either replace the oven control board or the entire range???Any help will be greatly apreciated!!! Thanks in advance.
