blockeight88
Can someone please share what exactly these cycles do to your laundry? What is the preferred wash temp/water level/ and spin? I have tried both the Perm Press I and II on my Kenmore's and don't seem to be noticing less wrinkles. Am I missing something?
From the manual:
The PERMANENT PRESS I Cycle
Includes a load cooling spray rinse that reduces wrinkling compared to other cycles. You can select up to 10 minutes
of wash time.
The PERMANENT PRESS II Cycle includes a load cooling process that reduces wrinkling compared to other cycles.
You can select up to 10 minutes of wash time.
NOTE: When the timer reaches PAUSE, the washer will drain and pause for no more than two minutes while some of the wash water is drained and replaced with rinse water.
From the manual:
of wash time.
