Kenmore Portable Dishwasher
Clean Filters
That's awesome that the filters have stayed so clean.
My parents' GE has the filter cylinder too, and theirs also stays mostly clean except for the spot nearest the wash pump inlet. A white slime forms there.
Otherwise everything else is squeaky clean.
Update: This dishwasher has exceeded my expectations except for the racks which need to be wider between the prongs. I am continually impressed with the washing ability. I rotate between One Hour Wash and Pots and Pans with Hi Temp. When I got this dishwasher I said that I was going to go outside my comfort zone and allow more baked on soils and scrape much less to see what it could do. Except for 2 rejects that were my fault due to loading, this dishwasher obliterates every stain.
Filter cleaning: Non existent. I've checked the filter probably 6 or 7 times and have found nothing except for a very clean piece of potato in the bottom of the tub that was too big to pass through the upper filter.
Running time: Pots and Pans with Hi Temp clocks in at about 2 hours and 4 minutes. The few times I selected Pots and Pans with Sani Rinse comes in at about 2 hours and 40 minutes. Because the results are so outstanding I don't even mind. It's also very quiet as it does it's job
Rating: A solid A
purges,
low end machines may have a purge feature in the control board, but not a turbidity sensor to sense soil particles.
This Kenmore is of the most basic Whirlpool Point Voyager DW design.
It does not wash only the top rack. It must provide ample water pressure to drive both wash levels together.
