Kenmore Triple Action agitator or Dual Action?
Murando351
Thanks for the info, you certainly answered some of my questions.
pierreandreply4
I can't get a used machine because I am very OCDish so it would feel icky to me.
Some more questions:
Does the Tub on the new Whirlpool/KenMore rotate clockwise/counter-clockwise during the wash cycle, like below machine does?
Can I retrofit a Mechanical Timer for the new Whirlpools/Kenmore?
Kenmore Model # 23102
http://www.sears.com/kenmore-3.6-cu-ft-top-load-washer-w/p-02623102000P
I talked to a Sales rep at a large Appliance store here and she said that if I turn off the machine while it is going through a Wash cycle or before it completes the whole cycle the machine will auto empty the Tub. Anyone here with an eletronic control Whirlpool/Kenmore , can you confirm this?
all I know is when it comes to the Cabrios.....if you hit the pause button, it just sits there, waiting to be restarted.....and when you do, it just picks up where it leaves off.....
same goes if you unplug it, no matter how long, once you plug it back in, it will continue from where it left off.....
but also, if you hit the OFF pad, and then try to restart a new cycle, you will throw it out of whack.....it will drain and spin, and then you have to let it sit for about 30 minutes before you can go again.....
in this one, you can't change settings mid cycle.....once you load and set it, you have to let it complete its task....there are some disadvantages to a electronic machine.....
but nothing says you can't adapt to one of these....selecting the 'heavy' cycle and soil level, plus add in a soak and extra rinse.....basically the machine will do everything that you would set out to do manually.....
