Kenmore Visimatic Wringer Washing Machine!!!
armorsecsys
Jan 16, 2015
0
St. Louis, MO
Hello!
I need a manual for a kenmore visi matic wringer washing machine. I am having problems with the wringer not staying lached in the lock posistion. The rollors are not tight enough to wring out the water... anyone have any ideas?
[email protected]
thanks,
Matthew
What year is your Visimatic?
I have the manual that covers the Whirlpool/Kenmore's from the early sixties to the early seventies. Many of these machines did not use an adjustable tensioner on the rollers. My machine had a problem with the wringer jumping off the post. Turned out to be a small pin that held one of the gears in place. I don't quite know how to upload the manual onto the computer, but I will sure make a copy and send it to you. E-mail me if you need it!!
kenmore wringer
Hi Matthew, Did you latch the wringers before trying to use? If not, lever will not stay engaged,and there will be a gap of about a half inch. Latching(locking in operating position) depends on model and year made. Early visimatics have an end panel which swings down,newer ones have a lever under the operating(direction) lever which swings out away from wringer body,while latest ones have a knob you pull out under direction lever. As for owners book,I have a couple for late 1950s models. Ebay currently has one available....look under "kenmore wringer", good luck,Walt
