Motor
It's clean and tidy underneath
I assumed it would be ok to start it as the new house holders who bought the kitchen had been told by the original it worked but they never used it.
It filled up and then heats , then starts, it's noisy , it then leaked around the door, so I tried adding some plates cups etc, and detergent. It leaked less then massive amounts of foam leaked out the door ! I added some fabric softener and this stopped but I discovered the drain pump didn't work so now it was full of fabric softener scummy hot water!
I bailed it out and washed all the dishes in my regular dishwasher.
I've since oiled the pump and I think it will be ok , and I think I can get new door seals.
The thing I've noticed about older dishwashers is , that it's hard to fit in modern crockery. The mugs I use just about fit in the top rack. Glasses have to be small. And as it's an impeller model anything in the bottom rack has to be a plate as it will block the top rack water spray.
I'll keep you informed if I can anywhere with it
I've posted a link to 1970s appliances. It's a silent film from Huntley studios , a short way in there is a dishwasher that looks like the kenwood.
Cheers Richard
