Kingston timer housing repair - suggestions?
swestoyz
Sep 27, 2004
6,633
Cedar Falls, IA
Hi everyone, I’m knee deep in an early automatic washer restoration, and one hurdle I need to solve is repairing this timer housing. It’s an early Kingston timer (made by Cramer), where two stand offs mount the timer to the panel.
Sadly, one of the two stand off mounts on this rare-as-hens-teeth timer are broken. I’ve had thoughts of trying to replace the one side with a later model Kingston timer that has the same contact points and update the harness to 1/4 spade, or seeing if some sort of epoxy could be used to fill in tue cracked area and tap it out one dried.
Any thoughts suggestions folks here may have?
Ben
Or
Before applying epoxy, coat the original screw with teflon lube in paste form not spray and kind of screw it down against the old post. As the epoxy hardens it should mold threads and you should be able to screw out the bolt.
But I would definitely go the epoxy route and keep the Douglas connectors.
Bill and Jon, thanks for your suggestions.  Bill's idea of using shrink tubing got me to thinking about using some vinyl tubing and finding some that fits snug around the outer diameter of the post, and coupling that with Jon's idea of coating the screw with teflon lube and allowing the epoxy to flow naturally between the screw/cracked housing/vinyl tubing.   That may just work!
I'd love to actually thread a stud into the post and cast it permanently in the post/mount, and install it to the panel with a nut on what was the screw head side, with a jam nut in place between the panel and the post/mount.  This way there isn't a potential for an increased amount of torque against the plastic fix as all the pressure would be applied between the jam nut and the panel.
Ralph, that is a good question.  A little reading just now on "epoxy vs JB Weld" has lead me to consider using JB Weld over epoxy.  I'll give this a bit more thought and will report back on the success/failure of the repair once I'm done with the washer.
https://welderquery.com/gorilla-epoxy-vs-jb-weld/
Ben
What about PlasticWeld Ben, I've used it, it dries and hardens relatively fast. It is a putty that you can mold into the shape of the broken side of that post. Then you can easily tap it once it is dried.
I'd be cautious about having any kind of lubricant anywhere near an area being glued...
seems like a high risk of contaminating the mating surface and weakening the bond...
Clean that surface really well with a stainless brush and some elect contact cleaner then apply some mil spec type of JB Weld and let it sit a few days. Then drill and tap the hole. You could slide a snug fitting piece of heat shrink tubing over it and cut it flush to get the basic shape of the stud. Then heat it after its cured and apply a second layer of tubing before drilling and tapping.
