After more testing, when you choose Soak/Scrub or Normal, is sits forever on 'Heating Water'...Ive let it go 30 minuets before giving up and choosing another cycle ..but when you choose Light China or Quick Glass, it quickly heats the water (5-7 min) and the cycle begins...the incoming hot water at the tap is 120F..if this is a timer issue, Ill just use those 2 cycles as they work well anyway...I have a spare timer that Ill try and see if that does it as well
