SEAimperial
- Joined
- Jan 19, 2012
- Messages
- 2
My KDI-16 is a real workhorse that's worked great for 42 years. Recently the detergent door has been a bear to keep shut over the main cycle well. It's got a button action in the middle of the door hinge that seems to help at times, though that's not consistent. The door works correctly during the cycle once I get it closed. I think it may be time to get a new spring (if that's what's used to keep the door shut) or replace the dispenser.
I'm having a time finding the part though. The detergent dispenser & gasket sub assembly with solenoid is part A-102830-1. I'm not sure if I need the whole thing or if just the body & lid sub assembly less solenoid, part M-83078, would do the trick. I'm attaching a link to the youserguide.com site where I found the parts catalog.
Any ideas on what I can try before replacing the dispenser? If I have to replace the dispenser, where can I find the parts?
Thanks for your input!
http://www.youserguide.com/wiki/Whirlpool_KDI-16_WITH_SOAK_parts-010
