kitchenaid KDI-17
das
Jul 7, 2022
2
Pottstown
help..washes dishes fine,BUT makes load,banging irregular noises during the wash cycle. also a secondary, much less noise at the same time during wash cycle. thank you for any ideas..
You probably need to check the wash arm and wash arm support for wear that will require replacement. Check to see if the 4 way Hydro Sweep sits level if you try to tip it from side to side and see if it spins smoothly when you give one of the 4 tubes a spin. It should coast to a smooth stop; not shudder and rumble.
