Kitchenaid KDI-18 dishwasher not washing/filling up
kimmith21
Member
Aug 7, 2025
7
Hello all!
I have a KDI-18 (installed in 1980). Recently, it began not properly washing. We replaced the wash arm support as we thought that might be the problem because the spray arms were not spinning/spraying. That did not fix the problem.
Here's what's going on when running a normal cycle... water flows in but does not rise to the appropriate level as it should. We thought maybe there wasn't enough water coming in, so we opened the door and added additional water from a bucket. But withing a few seconds it drained out leaving just about an inch left in the bottom of the machine. So now I'm not sure if its a water inlet problem or a drain valve problem. In either case, the wash arms never spin and spray water.
The other odd thing - when it hits the drying phase, it drys for maybe a minute and then water starts coming in. And the basin of the machine fills (like it should during the wash phase). Then it continues to dry again. When the cycle is complete, I have a machine full of water.
We've already replaced the timer with another used timer which did not fix the problem.
Any thoughts? Faulty inlet valve? Or is something going on with the drain? I love this machine and already had a repair man out, but he had no interest in troubleshooting it.
Thanks in advance!!
If it's filling during the drying cycle, draining during the wash cycle, and possibly not filling up long enough.... that sounds like a timer problem. Could possibly be the switch bank but I'm betting it's the timer.
The timer has been obsoleted for many years now but I found a new one on ebay if you want to take a chance on it.
https://www.ebay.com/itm/354669620020
Thanks for the response!
We thought the same thing so we did take a chance on a (used) timer from ebay. After we switched timers, it still wasn't operating correctly. Before I try with another timer, I wanted to check with the experts here 🙂
KitchenAid KDI 18 dishwasher problems
Something is certainly wrong and you may have more than one thing wrong on the surface. It does sound like a timer problem, but it could be others.
First thing to do is to find out why it’s not circulating water properly when the main motor is running, you said you poured water in and it immediately drained. I think that’s just a coincidence try that again whenever the main motor is running that machine should be circulating water at a great rate like a hurricane in a box they’re often described as.
The dishwasher should also drain properly at the end of each wash and rinse. Make sure the machine is mechanically capable of doing these functions.
I have no idea where you live, but you should be able to find a repair person with a little gray hair that can figure this thing out. This was a very popular dishwasher and easy to diagnose.
Good luck keep us posted
John L
John L
Thanks for your thoughts, John!
We've had 2 repairman out. First one deemed it a timer problem after we suggested that. Charged a crazy service call fee then never heard from him again because he "couldn't find the part". 🙄 The other repairman just said it was old and had too many problems. I did speak with a guy at an appliance shop that thought maybe it was the motor not having enough power to circulate the water back through. The motor sounds like it always did, so I'm not sure thats the problem.
We've dumped water in at several different points with the same result. The water doesn't stay and ends up draining without circulating.
I'm willing to purchase another timer (they're an easy install), but I'm not sure thats even the problem.
I'm in central Pennsylvania area - know anyone close by? 😁
I'd be willing to bet that you have something jammed in the drain valve.
A toothpick, a wire wrapper, etc. Something that could get past the mesh filter.
Back in the 70's, I pulled out many items that blocked the valve from closing completely.
You would have to dis-assemble the valve if the item can't be removed from the inlet side.
Hi Steve, thanks for chiming in!
I mentioned that to my husband because I thought the same thing (after doing my initial research). We have not checked it yet. But would it make sense that during the dry cycle, the dishwasher fills up and then just sits there full of water)?
I had similar issues with my KDC-17 and I ended up having to disassemble and clean the contacts of both the timer and the pushbutton switch. This is not a straightforward process and it's easy to lose parts, or end up with a timer that doesn't trigger the right contacts, but I was able to get it fully working with the reference in the service manual.
Thank you for this suggestion! My husband said he thought about that. We have another timer coming next week so if that doesn't fix the problem, we may have to try this.
It's much, much easier to do this if you have two timers. You'll want to have a multimeter so you can test that the timer follows the program sequence chart in the manual. There are quite a few different operations in the cycle for the KDI models, so this can take a bit.
UPDATE:
Took a chance with another timer (this time a brand new in box, not used). Thankfully I was able to return the first used timer I purchased.
So far, things are working as they should. Crossing my fingers this was the only problem.
Thank you all for your kindness and suggestions!
I ended up buying this new timer from ebay and so far things are working good! (Fingers crossed). Thankfully I was able to return the first used timer I purchased. Thank you for confirming my thoughts that it was the timer!!
When I first moved into this house 20 years ago, one of the things I did to my KDC19 was take the timer out, dis-assemble it, burnished all the switch contacts, and had a damn of a time putting it all back together.
Been fine ever since!
