Hello, Everyone. First time to post here. I have a 1976 KitchenAid KDS-17A dishwasher that I've managed to keep in good repair for the 18 years I've lived in our house. It is the only original appliance left from 1976, which is a testament to the durability of the machine. However, last night it overfilled and flooded the kitchen floor. Thinking it was a one-off, I cleaned up, hit "cancel/drain", and tested it with the bottom cover removed. I immediately noted that the timer/programmer ran continuously when the door is closed and the handle locked. Then when it got to a certain point in the program "POOF/FIRE/SMOKE" from the Molex connector on the left-hand side of the timer/programmer. The pins on the timer are toast, as are many of the contacts on the Molex connector. I've searched all the big supply houses, and the timer/programmer is listed as Not Available, as is the wiring harness. Looking for suggestions before putting this bad boy out to pasture, and I figured this would be the best place to post.
TIA for all responses!
