ponchoguy
Was wondering if anyone had any insights on this. This unit is from 1999 and belongs to my sister. She recently stated it started to leak between the door and the top panel.
She's been using Sam's Club tablets and lives in New Jersey if that gives you any indea of the water content. She has been using these tabs for a few months now and previously had no problem with them.
What happened was she called me that she had a leak. I took a ride there and found the pump cover screws all loose. Tightened them up. Also, the upper bearing on the lower wash arm was virtually gone, so I ordered a new one and she put it on. Still seems kind of wobbly, but is now better.
She sent me a video of the machine spitting out foam between the door and top plate right at the middle. Now bear in mind that when she first noticed the leak, she canceled the cycle, pumped out the water and didn't use the machine for a few weeks until I came up there to check it out.
I've read about vinegar and table salt being used to help dissipate the foaming, but what's causing this and any ideas on how to rectify this?
I told her to try to get the foam out and then see if we can get to a point where we are running only water to see if we get a leak. I've told her not to replace the unit because ANY machine will leak out foaming suds---old or new.
Any ideas of what to check would be great. I'm going to have to coach her through it to do it, since I can't be there again personally for a while. I can send whatever photos (or a video if this forum supports it) that you might need.
Thanks again.
Thanks again.
