Kitchenaid kuds25shbt1 trobleshoot
dermacie
Nov 25, 2014
498
my forever home (Glenshaw, PA)
Please help,
My kitchenaid Superba dishwasher is acting up. When I go to use it the super scrub button no longer works. Would the control panel need to be replaced? Or would it be the control board behind the panel?
Any assistance would help thank you!
Derek
If you have a voltage tester, you can test the keypad for failure. If the machine cycles properly, likely the computer is good. It is not uncommon for the actual buttons to fail.
Is that the only button that doesn't work ?
Tester
I will get a tester. The pad when you get close to it you can see multiple buttons are slightly lit. And I have had this problem many years back and a Sears repairman replaced the entire keypad with a new one. Only problem is they only make them in black now.
