Clarification
I have this same machine only one model year ahead. I bought it new in 2006. This machine does have temp control. it has 6 temperature selections, 4 of them are standard, hot\cold, warm\cold, warm\warm, and cold\cold. The other two settings are SensorSure Warm\cold and SensorSure Cold\Cold. The ATC warm is set at 95 degrees and the ATC cold is set at 70. BTW, don't be fooled by the "warm" rinse. The warm rinse is set at 70 degrees, the same as the ATC cold setting. I set mine on warm\warm year round. If it needs warm it will add it, if the tap temp is above 70 it will fill with tap cold. In the dead of winter it will rinse with almost 75% warm water. In summer, tap cold.
