KitchenAide Kdb-21 Dishwasher wash arm does not spin
joemc
Nov 10, 2021
0
PA
My daughter recently bought a house with all vintage kitchen appliances. The KitchenAide dishwasher Model Kdb-21 is not working. The lower spray arm does not move/spin. Any suggestions on how to proceed would be appreciated. Thanks! Joe
The spray arm is powered by the water that is forced through it. Although I am no expert, lift the spray arm up and out and look at the underside along with what it sits above when it is in to see if there is an obvious reason for not spinning. The spray are lifts out and goes on very easily.
Clogged sprayers
Check the ends of the sprayer arm for clogs. If there is gunk in there the arm should be removed, soaked, and then with a hose rinsed out by shaking the arm from side to side.
