This machine may have been marketed to men, and no man wants to see small or Ex Small on anything.Funny how that lowest water level setting isn’t Small or Extra Small…
Medium is probably half fill, Extra High is full fill. Just the typical marketing gimmicks.Funny how that lowest water level setting isn’t Small or Extra Small…
My take, based only on the knobs with no metallic chrome look to them is that is possibly early 1980s? Or did everything BOL go direct drive after 1981?probably from around 1976 ?
You could aquire this, maybe fix it, if something minor, switch agitators, and resell it.Have considered this one, only about 40 min. drive away. Not spinning, but I'd like the agitator out of it, maybe other parts for this '86 I picked up a couple of weeks ago.
Made in early June, 1986. I was surprised it was built that late, rare to see them. I worked at Sears in 86 when all the belt-drive washers and matching black panel dryers were moved to the center aisles and clearanced out while the new direct drive models were brought out and set up on display. That was in the late-summer early fall of 86. It didn't take too many days to sell all of the black-panel machines.Although I thought Sears direct drive models were phased in the model line and by late 1986 were all direct drive. Could have been made in early 1986. Definitely all DD by 1987
With the possible exception of his prostate... but that's another forum!This machine may have been marketed to men, and no man wants to see small or Ex Small on anything.
Hi everyone!
Chet - the timer in this 29401 does not seem to have been used in any models that had a third cycle, though I always wondered the same thing. There were however some models that used an identical cycle layout with a 6 minute “delicate” cycle with on-off pulses during wash agitation, intended for single speed machines. That timer however had a different part number. The 1981 models had new timers with a 180-degree sweep for the normal cycle (Cotton/Sturdy).
Have a good week everyone!
Gordon
Sorry Chet that I do not have a cycle chart pic. I can say that I never noticed the KM’s timer used in a WP model, but I did not scrub the parts catalog to check. I do know that it was used in the 76 model, the 77 model, and 1980 model all mentioned above, as well as this ‘79, but I am pretty sure that was all. Not a lot of models or longevity in use.
Gordon
Based on Chet's repeated assertions that valve 358277 is one of the best things man has ever created, I purchased said valve last month and I'm going to install it in my Speed Queen AWN542. Thank you, Chet. I am very much looking forward this potentially life-changing event.
Hi Chet , I’ve never seen such excitement about an inlet valve, lol
All inlet valves that whirlpool used on their washers in this time We’re dole valves. There are all the same quality there was nothing better about a 358 277. Yes it was a good valve but so were the blue valves and so were the red valves used in the compact machines and none of them exhibited any of the problems you mentioned in your overblown response.
When I rebuilt my 71 lady Ken Moore a couple years ago I put the blue valve in because I wanted the 6040 mix. I wanted a warmer warm since it was a sudssaver machine and I always reuse the water. Although in retrospect, I probably should’ve put the 50-50 valve in because I really don’t wash in warm water. I start with hot and it cools down for subsequent loads and with the 50-50 valve. I would get a little bit more robust spray rinse because my rinses are always cold.
Hi Gordon, I have a couple belt drive machines over at the warehouse that I have saved that came back from recent sales in the last year. I’ll have to post pictures of them. I’m not gonna keep any of them but maybe you or somebody wants them otherwise I’m just gonna recycle them. I already have too many parts stashed.
If anybody needs some belt drive transmissions, I was sorting them out. This is only about half the pile the other week. These are all in decent shape. None have water in them, etc., my only problem is shipping them. It’s too time-consuming if anybody wants to pick one up depending on the unit it would be between 50 and $100. I also have many agitators and GE FF clutch and motor assemblies that can be sold, I will probably just recycle all but maybe 6 of them soon.
John L
