The cycle programs and sequences on the newer machines can be totally reprogrammed. Parameters such as cycle time, rinses, etc are up to the programmer. The older Wascomat Gen 3, 4, and 5 (non Emerald series models) were harder to customize because of mechanical timers, contactors, etc. The cost to run a laundromat are quite high. You also have to remember that depending on the load capacity, those machines start in the area of $5,000 per machine new. So you have high costs for the machines, high costs for utilities, equipment repair costs are higher as well. It does not surprise me of the owner of a laundromat has to pay in the upward range of $1,000 to have a repairman replace the main bearings in a small capacity commercial FL machine. As time goes (years) the cost to run a laundromat get higher. So, I can understand why the vend prices are so high and the cycle programs are so short. Oh, as long as parts for commercial FL machines are in good supply, they can/are totally rebuilt. In my area I see a lot of laundromats with the Newer Dexter Throughbred T-600,T-300, T-400, and T-900 models. No SQ's, never seen any Ipso's or Maytag/Primus for that matter. There are still 2 laundromats out of the 6 laundromats in a 25 mile radius that have the older Wascomat Gen 4, and Gen 5 (non ES)machines. One of the 2 laundromat has only 2 Wasco's and the other one used to have all 5 rows of Wascos. Now they have only 2 rows. I'm trying to get on the owners good list to get one of those W184 50LB. machines from him when he replaces the remaining 2 rows. Also the newer machines are a little more efficient on power with VFD's running the drive motors. Most newer machines can run on both 3phase and 1phase power. In the past Wascomat and other brands of machines would require 3phase service. There were 1phase machines for the same models, however they are more complex, and more expensive to repair. As costs increase for operating Laundromats, you will see more of the customizable machines. Thinking business-wise, it is not cost effective to have machines that can't be customized and are considered less efficient. The owner can "adjust" parameters to off-set costs. I think since the economy is in the state that it is, you will see more of the newer ELECTRONIC customizable machines. Currently I have Wascomat W73(Gen3), and Primus W10 machines. If you have the means to get one of these machines, and can supply it what it needs, I encourage you all to get one. These older commercial FL machines are disappearing kinda fast.
