launderess
Well my barely used "new to me" AEG OKO-Lavamat has been playing up of late.
Sometime not long after arrival noticed the machine was not sending water down fabric softener compartment consistently. No worries as don't use the stuff much anyway. However later on the machine began not filling or doing so with a trickle of water on some cycles.
Monday night was the last straw; went do to a load on "Delicates" and the machine sat there filling for >15 minutes. Ended up having to pour water from kettle each time filling was required to get things done. That obviously is not a permanent solution.
Upon investigation is seems AEG washers of this vintage are prone to having water solenoid issues, and the triple water valve unit must be replaced. Is this a job a novice DIY person such as oneself can tackle?
Called Miele in when the valves needed replacing on the W10170 (the cold water went after >15 years but the tech said best to do both while he was at it), but am getting frugal and wondering if the AEG job can be done on a more cheaper basis.
Can order the part from AEG in Canada for nearly $150 plus shipping. Or, can have it sent from various spares places in Europe for around $60 or so plus shipping and VAT after exchange rate. AEG uses "Appliance cares" an outfit I've never heard of for their local repairs. Regardless have a hunch call out charges will be dear..
My copy of AEG service manual tells how to open up the machine, diagnose some issue and so forth, but gives scant information on how to replace actual parts.
