HI all
Yes I think the 250 is my favorite machine, must get over to Blackstone's to scrounge some more parts for it.
My 350 did the fatal break in the tranny,locked up, blew the motor etc. and had alot of other tub issues so it was parted out , And crossed the magnetic bridge last year. Hail Blackstone. Well I ran that machine 25 years.
I focused on getting the 250 up and running, now that she is sloshing away gracefully I want to give her a fresh coat of white this spring.
Mike I only used about a 1/4 to 1/3 cup of flakes for that wash, it just kept building ( i have very soft water here)!
I grabbed the camera when she started throwing suds up into the air-- ILUVTHAT.
You are right the machine is totally mechanical, the cycle control is run by flexi cable off the tranny as is the brake/clutch, and the water valve. No solenoids here they didn't believe in them in Buffalo! Absolutly forbidden!
When you wash you have to move the water temp manually to warm or cold or you get the same temp for wash as rinse.
alr2903 the drain in the tub works like this:
The humongously heavy tub sits on a giant rubber plate, under the agitator are 8 mega holes. For drain the mighty tranny lifts the whole shebang up off the plate and the water just gushes out the bottom, quite different from a Kenmo'. Then it cranks into spin, upon stop the flexi cable engages the brake, tub stops and as it stops it drops KerKlunk onto the plate sealing it for rinse fill.
ALL SILENTLY I must add!( except for the KerKlunk) This is one quite machine, unfortunately that video picked up the boiler and the Bendix and Artey in the background so it doesn't do it justice for silence!
Silent WashDay in your Blackstone!
