bluejay
I recently procured my first set of matching Maytags; I'm working on both concurrently, as the dryer should be fairly easy to get set up.
I did a fill test on the washer and all went well until it hit the spin cycle. It appears to be a leaky tub seal, I believe, as the arm underneath the drum is flinging off drops of water.
This is my first washer that I've worked on; what is the best way to go about replacing the seal, and am I correct in my assumption that it is the tub seal that's leaking?
Any help would be greatly appreciated.
