My first Vintage washer and dryer! 1980 Whirlpool belt drive set!
mattboe
Aug 13, 2024
3
Las Vegas, Nevada
Just bought my first vintage washer and dryer set! Ive always been a washer fan since I was a little kid and I finally got ahold of this working set for 80$. No big leaks yet although The washer has like a make shift drain hose that I want to replace. Any tips for that such as what size to use or if they still make a drain hose that works for this washer? Model number for the washer is lha6800G1.
    1.6 MB
    1.3 MB
    1.1 MB
Congratulations! What a great find! As regards the drain hose, you can pick up a new one that has an adjustable fitting at any hardware store. Good luck and looking forward to seeing more pics/vids!
I figured as much. I also may have to replace the hose going from the pump to the actual drain hose outlet. But I'm guessing I can also get that relatively easy at the hardware store too with new c-clamps.
Also check out The makeshift drain hose at the previous owner made lol.
    1.2 MB
    991.3 KB
I feel like modern day suspension washers could really benefit for a snubber like that belt drive has in the corner there. It would probably work wonders on all the balance issues today.
