I went to the Miele 1918a in the workshop this afternoon, in order to wash a throw rug with a deteriorating rubber backing. I scrapped and beat off as much of the rubber backing as I could, loaded it into the Miele, started a quick cold cycle.
After minute of cold fill I decided it would be a good idea to check the lint filter at the bottom front of the machine. With some difficulty I unscrewed that and then something interesting started to happen. The little drain tube connected to the filter door started to pour out cold water. WTF?
I got a pan to collect the water, go the filter all the way out, it looked OK ( I guess, not sure how much filtering it could ever do). Meanwhile I had to empty the pan. Screwed the filter back in (with difficulty, had to use pliers to grab it). And started the machine up again. Sure enough, water came pouring out of the drain tube again. Even with the filter door closed, it kept coming.
So I'm wondering, of course, why is it draining like that? Even with the door closed? Is there some sort of valve in there that keeps it from draining when the door is closed? If so, where is it? Right now I cannot use the machine because of this leaking.
I have a manual for it somewhere but it might be quicker to get some expert advice here.
Thanks in advance.
Thanks in advance.
