Leaning Tub
btjustice
Active member
Jun 17, 2007
33
Is it normal for a new Whirlpool TL tub to lean forward and to the right? If not, is there an easy fix to correct this? The washer is level and doesn't rock.
Try Shifting It to the Center...
Does manually shifting the tub to the center help or does it keep leaning to the front and right whenever you let go or after a typical wash? Otherwise, check with your dealer to see if something is amiss in your particular machine.--Laundry Shark
I can move it to center and it stays until I run a wash or a spin through it then it goes back to the same place.
