So, referring to that 1955 Kelvy manual, I kinda figured out that I should be able to remove the tub and drive shaft assembly in one unit. But to do so, I'd need to remove the pulleys. Seemed easy enough...
I had to remove the cross brace at the bottom of the cabinet. Word of warning to anyone else who may tear into an ABC machine like this- there's a ball bearing the size of a small egg at the bottom of the brace plate. Losing it is not an option... LOL Well, the plate came off fine.
BUT, this is where I'm stuck for the moment: the agitate pulley is not attached to the drive shaft with a hex nut. The manual calls it a 'split pin' but when I described it to Phil, he said it is really a 'spring pin' or 'roll pin'. Anyway, the manual said to 'drive out from either side of the pulley'. Sounds easy enough, but I don't seem to have the appropriate tool or punch to accomplish that. So, I'll be on the hunt for one of those this week. I hope our local Crappy Tire knows what the heck I'm talking about!
And I still have to get that pump clamp off somehow. So, I've got some challenges here. And it looks like POR15 is going to be my new best friend.... Stay tuned!
[this post was last edited: 6/20/2016-10:57]
