LG Front Load Washer
I''m having problems connecting to LG's server. I've just about had it. Everything else has progressed fine Checking the connection, security check, and still trying to connnect to the server And that's after I activated the WiFi. [this post was last edited: 9/24/2021-13:59]
Our Opinion.........
.....is that router performance degrades, over time.
Another thing to consider is that home appliances often work better on the 2.4 ghz frequency vs 5.0.
Also, home appliances often seem to hiccup when connected to a mesh routing system.
We are partial to Asus computers, motherboards, & routers.
Whenever a new router protocol is introduced, we usually invest in one of the highly-rated entry-level models.
Our current router is the AX3000 (RT-AX58U.) This is a "smart" router that automatically chooses which frequency is best.
Not sure how this happened, but I got it to work finally!!!
I got to see the downloadable cycles and saw there's one that's for ultra delicates. the only way currently to access ultra low temperature is via timed dry. This downloadable cycle is an auto dry using ultra low temperature, which I have a need for as opposed to the default downloable cycle Super Dry.
Join the club. I seldom if ever even use my LG washers connectivity but when we switched from our old cable service to this new broadband based tv and internet service they installed an new all in one modem/router. Since then it was hit or miss and I was spending ages trying to get it to connect and it seldom does so I've pretty much given up on it. It more annoys me that it doesn't work, even though as I said I seldom use it or need it,, it just bugs me when something doesn't work. LOL. Sometimes I can still ask Alexa what the washers status is, but again that's hit and miss. This new modem/router automatically switches from 2 to 5 g and I think that may be my issue.
Router Woes
When the smart thermostats first came out, we were guilty of blaming the software or apps for all the dropped signals. Later, we found it was usually the router's fault.
Our latest router hasn't missed a beat when connecting to our smart devices. So far, ThinQ has done everything it's supposed to.
Also, I ThinQ most of the Smart Connect-type routers will allow the individual clients (devices) to be locked on one of the frequencies, or the other. You would have to log in to the router to change the settings.
WiFi routers should broadcast on both bands.  They should be configured with different network names (SSID) for the two bands so one can knowingly choose which band for connecting a device.  The passwords for the two bands can be the same for the convenience of not dealing with two different passwords, or the passwords can be different ... either way won't affect the device connection which is chosen by the network name.
2.4GHz has a larger signal coverage area but slower speed.  Some devices such as thermostats and appliances may work only on this band.  Check your router settings to be sure this slower band is enabled and properly configured if you have such devices involved.
5GHz provides higher speed but smaller coverage area.
5 GHz Router
The Kenmore’s and LG WashTower would never connect with 5 GHz. Always 2.4 GHz.
I always found the Permanent Press cycle to be great on the WashTower dryer.
Netgear Smart Connect
I have been following this discussion with great interest as I would lean toward LG if I were choosing a front load. I would consider the SQ FF7, but the cost difference is more of an issue (than MT mwwp575gw vs TC5000) here plus I really did like my old LG's sani-cycle.
Netgear has a feature called Smart Connect.
Enable Smart Connect - Let the router intelligently select the best 2.4 GHz or 5 GHz WiFi band for your WiFi connections. Smart Connect requires that the 2.4 GHz and 5 GHz WiFi networks use the same WiFi network name (SSID), security options, and password.
When a device can use either, the feature seems to know whether the longer range or higher speed would work the best for a particular situation.
This feature should be available in other routers although it may go by a different name.
Side Note. I created one network for my devices that uses Smart Connect. I use the Guest Network for the kids. On the 2.4 band, I allow them to see each other and allow access to local network. Some on this board may want to use that for lower priority devices that can quickly be booted off if needed. I use the 5 band for guests only. It has a different pw than the 2.4 and no access to see each other or to the local network. I can just change password if needed without affecting the rest of us.
5.0 For Guests Only......
....5GHz should probably remain reserved for applications that require a great deal of bandwidth.
Example: Someone has "Cut-The Cord," and has multiple "streaming" devices situated around their home. They have decided to rely on a WIFI connection, in lieu of the expense of hard-wiring these streaming boxes, or Smart TV's.
Smart toasters, refrigerators, + washers & dryers probably better off remaining on the 2.4GHz frequency. Eventually, this could change; but, for now, this is probably the best way to think about setting up a new router.
Forgot To Mention.....
....it's probably still too early to expect manufacturers to design products that cooperate with all the latest frequencies & protocols.
Seems like the newer routers are way ahead of the game.
We prefer to take a "Keep It Simple" approach to these new technologies. We figured out what works, and doesn't work, for now.
Most devices and usecases don't saturate a 5GHz link. Neither does basically any household internet connection.
5GHz is great for multiple clients though.
Theoretically, both bands can accommodate the same number of clients as long as the access point can handle them IIRC.
It's just that once you have a dozen or so devices, 2.4GHz might get crowded.
If you live in a flat or close to many others, it can crowded too.
Many routers check bands and channels automatically and adjust accordingly, some have to be triggered manually to do so.
