Not everybody here knows this but there is a way to test for any failiers using your control board.it will do a thorough test on different features and performance.You need to press two of the buttons(spin speed and soil level)together and press the power button just after and during the presure on them.The entire panel will illuminate and as you release the buttons.For each feature tested there is a pattern you need to follow and the timer dial is all you need to use now the test system is on.
1)Press it once to check the clockwise tumble and pump functions.
2)Press it twice to check the low rpm spin and drain.
3)Press it three times to check the high rpm spin and drain.
4)Press it four times to check the pre wash temp and deergent dispenser made for that cycle.
5)Press it five times to check the main wash detergent dispenser.
6)Press it six times to check the fabric softner dispenser.
7)Press it seven times to check the bleach dispenser.
8)Press it eight times to check the counter clockwise rotation and pump.
9)Press it nine times to check the water level for soak.
10)Press it ten times to check drain pump.
If you check the spin rpm and want to proceed to the next test i.e.main wash,press the timer twice AND WAIT FOR THE DRUM TO COMPLETELY STOP.It will proceed to the selected trial once the drum stops.
remember,this is a test.Be sure there are no clothes inside!!Especialy when testing the spin RPM velocity.If there are clothes inside during this specific test,you will damage the machine.The two spin tests make the drum go imediaely to either 800 or 1200 rpms within ten seconds!!!!!If there are clothes(especialy wet ones)inside,the severity of the unballanced,high spinning tub's vibration will cause permanent damage to the machine.Unlike the actual cycle that sences the tub ballance,this does not ,and will not, stop untill you press either the timer dial to set the next test procedure or the power button to completely shut the unit off.to end the test(s) just press the power button.
I hope this helps those who ,like myself,love their L.G.washers and want to learn as much as posible about them.That way,if service is ever needed,we can test the tech they send out to see if they know any more than we do about them.I actualy like the direct drive as aposed to belt drive.It is a bit quieter and less to go wrong.
CHUCK
