Last month I installed a new LG front loader in a somewhat challenging location because of a drain 6 feet above the floor.
Sure enough, just like the old top loader, water was left in the tub at the end of the cycle.
I watched it spin for the final 16 minutes- without ever engaging the drain pump.
There seem to be many periods in the cycle when it spins- without draining- or pauses to tumble and drain before spinning again.
I called LG customer service, described the situation, and was told this is perfectly normal!
No, I said, I don't want clothes left in a 2" puddle of water at the end of the cycle.
"Normal" she replied. "That's how it's designed. If I want to drain the machine, I can use a hose to do it manually."
So I'll work with the dealer & see if his tech has any better info.
But how can this make any sense?
Anyone else have this experience with LG?
Any suggestions, short of a sledgehammer?
