niclonnic
I've had this LG front-load steam washer for 4 years.
Last night I decided to clean the pump filter, after having not done it in a long time. So I opened the access door and drained the water into a measuring cup. It was filthy! Then I took out the pump filter and found it clogged with hair and rubber bands. But I found something peculiar.
The hair was coated in a slimy blue substance. I thought immediately that it was attributed to our use of laundry detergent pacs. I think the plastic fails to dissolve completely in cold water, as on warmer temperatures, they dissolve completely. But on rare occasions, the partially dissolved pacs get thrown forward and onto the front seal!
Do you think that laundry detergent pacs are the cause of this mysterious blue slime? Here are some pics.
