Hi,
I bought an LG WM1355HW front loader last week to replace a low-end, 17 year-old GE top loader that broke down for the 3rd and final time. So far, I love the LG (it's my first front loader ever) and am using Nellie's All Natural Laundry Soda:
http://nelliesallnatural.com/internal/?type=Laundry
I use 1 tablespoon (or one scoop) as directed. The machine is 2.7 cubic feet capacity and the water in my little apartment is soft. I chose this detergent because I read that it doesn't create a lot of suds which means less chance of moldy smell, and I wanted to use something a bit more eco-friendly after years of using Tide, Sunlight, etc.
So far, I've only done 5-6 loads, and the Nellie's soda seems to dissolve very well. There is indeed little to no sudsing. I have so far resisted the temptation to put in more than one scoop per load. Also, the detergent dispenser drawer is clean as a whistle after every load--no undissolved powder left behind.
But I found this webpage that says powered detergents can damage a washer compared to liquid detergents:
http://washerfan.com/faqs.htm
"Liquid vs. powder HE soap. This statement stirs a lot of debate. The Washer Fan™ team has personally worked on and completely dismantled dozens of washers. We have observed that powdered soap can literally destroy a washer because of the un-dissolved powder residue that coats internal parts. A washer with an internal coating of powdered soap residue is prone to mechanical failure and is more expensive to fix than its replacement value. We have disassembled washers whose owners used way more than the recommended amount of liquid detergent that resulted in a slight film coating on all internal parts. We determined that the film coating didn't damage the washers and that average use expectancy was not shortened; however, there was a severe mold and odor problem. In the final analysis, don't use powdered detergent in your washer and use the recommended 1 to 2 tablespoons of liquid HE detergent to reduce mold and odor."
So now I am confused and concerned. Should I continue using the powdered type, or should I switch to liquid? I want this washer to last as long as possible.
Thanks for any advice you can give me!
Allan
Allan
