Lightburn Easy Twin
brisnat81
May 5, 2004
2,243
Brisbane Australia
Can we all say Windscreen wiper :)
We picked this machine up this afternoon.
It was the pinacle of simplicity in 70's twintubs.
You turn it on at the mains, and start and stop it by opening or closing the spinner lid.
There is a single control which opens the drain valve, but other than that, it all runs from one motor with spaghetti pulleys.
Wash Tub
When I plugged the machine in, it tripped the earth leakage switch rather than the circuit breaker, so I'll need to get my multimeter out and find out where the problem is.
Pump Control
This valve only controls the draining from the wash tub.
Whenever the Spinner is running, it drains water from the spin side. Thus the cute suds saver hole in the wash lid to allow the water back in.
Finally a fronton view
With the great 60's/70's logos.
And a big thankyou to Michael for his efforts in making it shine. It was dull and filthy when we picked it up.
Lots of Windex and car polish later its as good as new.
Hi Nat
I LOVE those Lightburn Twinnies. There must have been a wide variety of models as I have seen about a dozen and no two identical. I haven't seen one for over 10 years, though.
The spinner outer tub is galvanized sheetmetal which rusts away - check you don't have any leaks dripping onto the motor or wiring.
There is no seal where the spinner shaft passes through the spinner outer tub. The tub has a raised "collar" in the centre, about 3 or 4 inches high, and the spinner can has a dished base which goes down around the collar at the outside. So the collar fits up under the spin can into the dished section. To not leak, it depends on the spinner pumping out the water faster than water is spun out of the clothes. It is possible to load too much water into the spinner, it overflows over the collar and over the spin motor, though there is a shroud over the motor too. Not really up to modern safety standards...
Another cause of overflowing in the spin can - there is a one-way valve between the spinner and the wash tub, so that if you open the drain valve when the motor isn't operating, you don't drain the wash tub into the spin tub. If the non-return valve (from memory it's a rubber flap inside the pump??) is damaged, then when you open the drain valve and the pump isn't running, water flows from wash tub to pump to spin tub over collar onto motor and floor.
If any of these events have happened, the wiring or motor will be wet, which would trip the safety switch.
Another trouble I had with one of these - the wash tub seals to the top via a rubber seal like a diaphragm - a rubber sheet which fits over the wash tub and has a square hole in it to fit the aperture in the grey fibreglass top panel. The rubber disintegrates over time, the wash paddle is very vigorous and flings water up against the seal with every stroke. If the seal is damaged, water gets up and over the edge of the wash tub.
about 15 years ago I did rust repairs on one of these twinnies, the same as yours except twin motor. The old Scottish lady who owned it was the grandmother of a friend of my partner. She had owned it since new, about 25 years at the time. She bought it on the recommendation of a farmer she knew who ran a sheep staion. they said no other machine coped with serious farm dirt like the Lightburn.
Best of luck with it.
Chris.
Thanks for the info Chris
Next weekend I'll have a look underneath and see if I can figure it out.
Its such a complicated design.
There's no rust underneath that I can see, but I'll take the top off during the week and have a look.
OMG!!!
Hi Nathan
What an absolute find, you guys are finding some classic stuff...now we can actually see what these machines look like instead of the adverts etc,,
Is this the one with the "Wonder Wand Wash Action"...is it a back & forth wash action that "Spanks" the clothes....hey Louis I think this is what Jet means by "Spankulation" wash action...LOL
Looking forward to seeing it wash, nice yellow colour as well, the spinner looks very much like the rolls machines , also the wash filter bowl as well...
Well done and to Michael for the polish & shine...
Mike
For years I have wondered about the wash action of these machines and having had it described to me have never really understood it. Great to actually see the water wand. If must make for a very splashy and violent wash action although I wonder how rough it is on the fabric? What an unusual design for a wash action!
Ahhh.... to see that paddle going
in an empty tub and then watch as the tub fills--how cool and never-before-seen that would be.
What a lucky find and the Scotch Lady, too :-D
At first glance I was wondering the same thing Louis, what is that big thing sticking down into the wash tub. VERY COOL Nathan! I would love to see what this thing looks like washing.
I'm not sure how fast yet
I dont know how fast yet the paddle moves, I'm assuming it is pretty slowly.
The machine was reported on in one of my choice magazines, it was rated ok, the thing that Choice loved, was how simple the controls were.
I'll try this week to find out where its shorting and bring it to life :)
Hi Nathan,
congratulations on your new machine..it's cool...coincidence as today's POD say's no more 'yellow and gray'
Let's say 'YAY! FOR YELLOW AND GRAY!!'
Can't wait to see some pics of that paddle in action, thanks for sharing, Denis
