Hi,
LG front loader (wm900hva). Had it for 6 months and first front loader. Using Tide + Ultra Stain Release liquid (top ranked liquid in Consumers Reports). The liquid detergent residue stays behind in the dispenser at the bottom. I watched a whole cycle to see what is going on. I am NOT overfilling - in fact, tested with using less than Maxand less than normal
- I took apart and cleaned the dispenser (no gunk on there anyways)
- I put detergent to the Normal line in dispenser (not the Max line)
-the siphoning in the dispenser doesn't seem to work well, the thick detergent stays at the bottom and then of course is still reapplied during the rinse cycle
- I purchased another bottle of Stain Release Tide at a different store - same issue and same thickness of liquid left behind at the bottom
So basically - either the soap is too thick and won't dissolve r the washing machine has an issue. Tide Pure seems to dissolve just fine and is't left behind, however it is mostly clear and not dyed blue. I haven't tried any other detergents yet other than above.
anyone else with a. similar issue? any solutions? is it a bad dispenser or bad detergent?
