Again - the VAS really dosen't run to give the smoothest spin possible, but to make as many spins as possible reasonably smooth.
I don't hear the VZug any less throughout my flat - just it's always that way.
I saw the VAS fail once on a very sudsy wash which I say was due to suds blocking the water from makeing it through the little air gap and into the collection rim at an appropriate rate.
It aborted that try and ran the interim spin without any VAS action.
The next one did again and worked as usual.
The washer can not add extra rinses, it can only cut a rinse if needed.
Found that actually manually adding a rinse dosen't alter water usage much - it usually leads to 2 high followed by 2 medium rinses instead of 3 high ones.
Have to do some more experimenting there!
